hi eweryone
I need to install DeviceNet. When I make the settings in the pictures I get these errors.Dipswitches on card are all off for rack 81.
The status is not online on the tp screen menu and i get the "board could not be set online" error.
Where do i make mistakes?
please help me these error.
Thanks in advance
RJ2 DEVICENET SETUP ERROR
- yunusdereli
I was setting DeviceNet on R-30iB few days ago.
Are you sure about MAC 61?
On screen (Board menu) from your picture you are setting DeviceNet interface for DeviceNet card on robot side. For communication with external device, you use other menu (Device menu). In my case with only one DeviceNet daughter board rack was 82.
Also you should add terminating resistor on both ends of communication line.
Did you supply V+ and V- with external 24V? And devicenet requirement termination resistor on both side. I don't see on the Picture.
I was setting DeviceNet on R-30iB few days ago.Are you sure about MAC 61?
thanks for answer.
yes i'm sure.
I tried the rack 82 I got the same error.In the picture there is macid:61 dipswitch address on daugterboard.
24 V feed from outside and I added termination resistors, but the problem is still the same.
Do you have another suggestion. -
I think your DIP switch sets MAC 11
Have you made any progress?
I would try setting daughter board on all racks.
I also set slave input and output to 512 bytes.
Thank you for your interest dha;
I tried all of them rack 81-82-83-84 But the result is the same.I will try slave settings.
Dn and dnp are these settings in the picture. What are we using them for.
Is the daughterbord dipswitch for the MAC or for the board number ? (BOARD 1-2-3-4) -
I have a question, Was it working before?
The dip switches are to set the Board number. The MAC ID is set in the software.
Something I saw is you are probably using a SST-DN3–104 daughterboard. I've seen these boards be used in R-J3iB and later. I am not sure if these daughterboard is compatible in R-j2
For R-J2, the 5136-DNP Daughterboard is normally used.
Try changing Baud rate on board and wago to 250 if set at 500 and vise versa. I had a cell that gave me fits until I did this.
I have a question, Was it working before?The dip switches are to set the Board number. The MAC ID is set in the software.
thanks for answer
Does not work before.I want to add new.
I did not know about R-J3iB.
I will try with a 5136-DNP card. -
Hello.
Did you solve the problem?
What are you doing?
I live the same problem i have.
Are there any friends that can help? -
Hello.
What are you doing?
unfortunately,The error is still going on -
hi error is solved?? can u attach the all of the above backup for more understanding
Yunusdereli greetings, I am writing from Turkey. I don't know if you solved the problem. I read what you wrote but as far as the card you are using is not compatible with rj2 eat. I've installed this card e RJ3 and smoothly it worked. RJ2 eat when we attempted to follow, more expansion card before installing the module was giving errors. If the card is already compatible with the robot DeviceNet I/O settings when auto-detect is selected, the red LEDs should be unlit on the card. The first card of the normal Plug-and-select auto-configuration, let's DeviceNet expansion card module of the robot without one you need to see him before he knows how. Kolay gelsin..
I have some issues with the configuration of migatronic welding machine to Fanuc robot Devicenet. It shows DNET-122 DEVICE ERROR & DNET -092 OUTPUT SIZE ERROR PLZ SHARE SOME HELP
