Help. Problem with installation of SRS 5.1!
  • Hello there,
    I installed SRS 5.1. When i try to create a new porject and select the Robot that I want to use, the library with robots doesn't appear inside.
    Otherwise, if I want to open a project, I received an error : emulator 7.9.1 not installed or invalid (i have installed this anyway).
    I am having this problem from one week, tried to install also the version 4.2, but the same problem.
    I use Windows 10.
    Can anybody help me with this? Thank you!
  • Hi VasileDan,
    usually this happens when you install SRS directly out of the zip file. Try to decompress the file first.
    Greats Psyril
    The difference between theory and practice is greater in practice than in theory.
