We have a Fanuc r-2000ia with a rj3ib controller. We are adding an Allen Bradley Compact Guardlogix Safety PLC and distributed Ethernet IP Guard Point IO blocks (1734-OB8s) to the cell. I have always just dealt with the safety circuits in series. What do people use for the estop and fence circuit in this scenario? I was thinking of using a MSR126T relay connected to the plc output and robot safety circuit.
Fanuc Rj3ib and Safety PLC
Wobblysquee -
July 10, 2017 at 3:59 PM -
Are there no relay output modules for this safety PLC?
On older Ford cells I've been on, they used the 1791ES-IB8XOBV4 CompactBlock Guard I/O EtherNet/IP Safety Modules. I am not sure if they were paired with safety relays though. Judging from the documentation, they probably were. I never looked at the setup very closely.
With the Guard Point Blocks, I think you would be able to use the 1734-OX2 module, and just wire the fence and stop circuits directly. I am not sure on this though either.
Thank you for the replies it looks like the 1791ES-IB8XOBV4 is a similar setup to the 1734-IB8s and 1734-OB8s that I am using. I will need a SIL3 compliant relay so I believe the 1734-OX2 would be out.
The safety function(s) are in the PLC safety task, you just have to pair up the robot's fence and e-stop inputs with PLC safety outputs and program the safety task. Pretty standard stuff.
