Creating a spline from JointPosition array
  • Hello everyone,
    A bit of background of my program. I have created a Java server that connect to a windows c# based client. With this connection I am able to pose the robot, get current joint positions, and etc.
    My current issue is that I am unable to Stream a set of Joint Poses to the robot and have the robot follow a predetermined path. On the c# side, I am recording the joint positions of the robot every 100ms for path recording. After this I pass the Joint positions, about 71 different poses in this case, to the robot I want to create a spline of all these "frames", which are stored in a JointPosition array.
    At the moment I am using robot.moveasync with PTP motion to complete this task, however the robot takes way to long to execute the entire path. After speaking to a KUKA rep, they pointed me to use the Spline motion to complete this task. However with the Spline method, I am unable to create a dynamic spline based of the number of joint positions passed through my C# client.
    Any Ideas?
  • I recommend reading READ FIRST since you succeeded in providing absolutely no information about your system. It is even uncertain if you are in the right forum...
    Edited once, last by panic mode ().
