I need to make DCS zone around my gripper. Last time the was not any issue with this. In new project I set everything in the same way, but it does not work. In attachment you have my settings. Do you have any idea why this zone is invisible? With this size it should be really huge box.
DCS User model on Gripper - invisible
sklimosz -
June 30, 2017 at 1:06 PM -
Did you set this user model as the target of an active CPC zone? It will not show up until then.
Exactly as HawkME says, you have to set the model as a target for at least one DCS cartesian-position-check function (CPC) to make the model visible.
Go to a zone's setup and input the user model's number in the Target Model section (as the second position, the first is the robot as default). -
That was it. Problem solved. Thank you.
