We have a pair of (used - new to us) Fanuc R-2000iA/210F robots with R-J3iB controls (Handling Tool Version V6.40-1K). I am currently getting a PRIO-063 Bad I/O asg error: Rack 85 Slot 21 error on both robots. It doesn't seem to affect them in their tasks/programs, but it's annoying seeing it on the screen (and maybe it does affect them in some way). After some research I found that Rack 85 is the ControlNet rack. These robots do not have the ControlNet cards installed. The programs I've created do not call these addresses at all. Under this error (http://alarmcodes.com/fanuc-ro…bad-io-asg-rack-d-slot-d/), it says to delete or update the assignments, but to this time I haven't been able to figure out how or where.
When I go to the I/O ControlNet board detail, I get:
Board: 1 Status: NOBOARD
Motherboard: Full-slot
Operation mode: ADPTR
Param Change Mode: NET ULK
Input error state: ZERO
Scanner Err sevrty: STOP
Adapter Err sevrty: WARN
ControlNet Parameters:
MAC-ID: 30
NUT (us): 100000
SMAX: 0
UMAX: 99
Slot (us): 254
Gbpre (10us): 92
Gbstrt (10us): 61
Gbcenter (10us): 45
In Device List (DEV-LST) there is also a device with the following settings:
Input Header Words: 0
Status: ON
MAC ID: 0
Device Name: [ ]
Comment: [ ]
Vendor ID: 0
Device Type: 0
Prod Code: 0
Maj Rev: 0
Min Rev: 0
Digital Inputs: 0
Digital outputs: 0
Analog Inputs: 0
Analog Outputs: 0
O-T RPI (us): 0
T-O RPI (us): 0
Path: [ ]
When I checked the SUMMARY.DG file (which I found during my research), it shows RACK 85 SLOT 21 under the following I/O:
IO CONFIGURATION::
DIN[ 1] START CYCLE
DIN[ 4] RECIPE 1
DIN[ 5] RECIPE 2
DIN[ 6] RECIPE 3
DIN[ 7] RECIPE 4
DIN[ 8] RECIPE ENABLED
DIN 1 - 8 RACK: 1 SLOT: 1 PORT: 1
DIN 9 - 16 RACK: 1 SLOT: 1 PORT: 9
DIN 609 - 616 RACK: 85 SLOT: 21 PORT: 1
DIN 617 - 624 RACK: 85 SLOT: 21 PORT: 9
DIN 625 - 632 RACK: 85 SLOT: 21 PORT: 17
DIN 633 - 640 RACK: 85 SLOT: 21 PORT: 25
DIN 641 - 648 RACK: 85 SLOT: 21 PORT: 33
DIN 649 - 656 RACK: 85 SLOT: 21 PORT: 41
DIN 657 - 664 RACK: 85 SLOT: 21 PORT: 49
DIN 665 - 672 RACK: 85 SLOT: 21 PORT: 57
DIN 673 - 680 RACK: 85 SLOT: 21 PORT: 65
DIN 681 - 688 RACK: 85 SLOT: 21 PORT: 73
DIN 689 - 696 RACK: 85 SLOT: 21 PORT: 81
DIN 697 - 704 RACK: 85 SLOT: 21 PORT: 89
DIN 705 - 712 RACK: 85 SLOT: 21 PORT: 97
DIN 713 - 720 RACK: 85 SLOT: 21 PORT: 105
DIN 721 - 728 RACK: 85 SLOT: 21 PORT: 113
DIN 729 - 736 RACK: 85 SLOT: 21 PORT: 121
DOUT[ 1] IN AUTO
DOUT[ 2] IN HOME POS.
DOUT[ 3] CYCLE COMPLETE
DOUT[ 4] ROBOT ESTOP
DOUT 1 - 8 RACK: 1 SLOT: 2 PORT: 1
DOUT 569 - 576 RACK: 85 SLOT: 21 PORT: 1
DOUT 577 - 584 RACK: 85 SLOT: 21 PORT: 9
DOUT 585 - 592 RACK: 85 SLOT: 21 PORT: 17
DOUT 593 - 600 RACK: 85 SLOT: 21 PORT: 25
DOUT 601 - 608 RACK: 85 SLOT: 21 PORT: 33
DOUT 609 - 616 RACK: 85 SLOT: 21 PORT: 41
DOUT 617 - 624 RACK: 85 SLOT: 21 PORT: 49
DOUT 625 - 632 RACK: 85 SLOT: 21 PORT: 57
DOUT 633 - 640 RACK: 85 SLOT: 21 PORT: 65
DOUT 641 - 648 RACK: 85 SLOT: 21 PORT: 73
DOUT 649 - 656 RACK: 85 SLOT: 21 PORT: 81
DOUT 657 - 664 RACK: 85 SLOT: 21 PORT: 89
DOUT 665 - 672 RACK: 85 SLOT: 21 PORT: 97
DOUT 673 - 680 RACK: 85 SLOT: 21 PORT: 105
DOUT 681 - 688 RACK: 85 SLOT: 21 PORT: 113
DOUT 689 - 696 RACK: 85 SLOT: 21 PORT: 121
When I check the I/O Digital configuration, it shows:
# RANGE RACK SLOT START STAT.
1 DI[1-16] 1 1 1 ACTIV
2 DI[17-512] 0 0 0 UNASG
1 DI[1-8] 1 1 1 ACTIV
2 DI[9-512] 0 0 0 UNASG
(No range above 512).
So, how do I delete or update the assignments?
Thank you,
Andrew
