We have a KRC4 robot and would like to set the $OV_PRO speed to run at a slow speed when it sees an input from a sensor and then at a faster second speed if the input is not seen.
The code that is written at the top of the sub routine at the moment is,
IF I_SHELLS_OPENED_PIECE_ON THEN
$OV_PRO=50
ELSE
$OV_PRO=100
ENDIF
I_SHELLS_OPENED_PIECE_ON is the input from the sensor.
What is happening is that the robot runs at 100%, sees the input and then slows down to 50%. When we lose the input the robot stays at 50%.
Is there a way to run at 50% when seeing the input and 100% if not?
We have multiple programs being called so this change will be in not just one.
