Hi all,
Can I change the velocity of KRC4 during movement?
For example, robot performs the LIN movement from P1 to P2 (distance between P1 & P2 is 300mm) with a velocity as a variable written from PLC (Syntax: LCPDAT2.VEL = VelocityFromPLC)
The value of 'VelocityFromPLC' changes frequently (20 times in a second)
I want that with this change in 'VelocityFromPLC' , the robot should also change its velocity maintaining its movement
Thanks in advance
