I'm working on creating a virtual communication connecting a simulated PLC (PLCSim advanced) to a Fanuc robot simulation (Roboguide).
The PLC must also control the operator panel (DI[1-18] linked to UI[1-18], UO[1-20] linked to DO[1-20]).
I tried to test controlling the UI by setting them to a range of unused flags. I could see the flag values change but when I tried to set certain values like: UI[9] RSR1/PNS1/STYLE by setting the corresponding flag, I noticed that the value is almost immediately turned off. (as far as I know, there are no background programs running).
Since this didn't work, I tried to use an external connection connecting DO to the UI as shown in the attached image. I also had to set RMT master to 0 and remote/local setup to remote.
This did work but I'm looking for a solution that is easy to implement and the 100ms monitor interval is not ideal.
Therefore I'm wondering if anyone knows how to set the UI (including the UI that should always be high) without using the external IO.
Thank You,
Bastiaan
