Did anyone connect motoman controller to Proface HMI?
I want to know, how can i change job from HMI?
Connect controller to HMI
- TSGIR
Hello Asgary,
I think the simple way is change one variable and create a master job to read this variable.
You can use one IG to write these variable in the controller.
For examble:CALL JOB 1 IF IG# XX 1
CALL JOB 2 IF IG# XX 2P.S. I,m not in the factory now to confirm the "program" above.
For me this is the simpliest way.
Hello
Thank you. it is a way for this purpose but in proface hmi i write a program that i can see all JOBs in controller but i couldn't select new job from that list because new JOB that i select couldn't select in controller and only select in HMI. i use 0x73 command in hmi for read job from controller.
