Adding DeviceNet master card on KRC4
  • MissM
  • May 25, 2017 at 10:39 PM
  • MissM
    Hi Everyone! I hope this will be an easy question to answer :
    I have a kuka robot (KRC4) with deviceNet slave card installed and configured, all working. DeviceNet Master is a PLC. Now, for some application, I need my robot to be master on the network. So, I need to add the DeviceNet master card on the robot. I already have the card and I understand that I should put it between the EtherCat Adapter and the DeviceNet slave card (tell me if I am wrong), but there comes my problem :
    --> How do I pull out the whole deviceNet I/O bloc from the din rail ? I don't see anything I can push or pull with a screwdriver like there is usually on din rail mounted equipment ! :hmmm:
    I haven't found any information in the DeviceNet Manual, so if anyone knows, it would be appreciated!
    Thanks a lot!
  • panic mode
    1,280
    13,086
    • May 25, 2017 at 11:28 PM
    [size=2px]This has nothing to do with DeviceNet, it is general info for this type of products and it is irrelevant of module function of used fieldbus type.[/size]
    Just power down I/O block and locate orange tabs on side of the module. gently pull the tabs (towards you) to unlock module from DIN-rail. while unlocked you can slide module out. Often modules can be removed out just by pulling on those tabs but - they also sometimes brake and then you are in trouble, so i suggest caution.
  • MissM
    • May 26, 2017 at 7:21 PM
    Thank you, I hadn't seen the tabs! It worked!
