i'm actually working on a Kuka iiwa r800, i want to calibrating a base with 3 point, i want to do it directly in the script, not in the SmartPad. Is there any function that already exist ?
Kuka iiwa r800 : Calibrating a base in the workbench with 3 point
- Magik07
It seems that there is no such api in sunrise api. So I wrote something like the following as the base generator for our project.
Display More/** * Generate a base frame from frame point a, b, c by right hand law. The base frame' z direction is the normal * direction of base abc. */ public static Frame generateBaseFrame(AbstractFrame a, AbstractFrame b, AbstractFrame c) { Vector startZ = Vector.of(0.0, 0.0, 1.0); Vector direction = a.getOriginOf(b).toVector().crossProduct(a.getOriginOf(c).toVector()); if (direction.equals(Vector.of(0.0, 0.0, 0.0))) { throw new IllegalArgumentException("These 3 frames can't produce a base frame."); } double rotAngle = startZ.angleRad(direction); Vector rotAxis = null; if (rotAngle == 0.0 || rotAngle == Math.PI) { rotAxis = Vector.of(1.0, 0.0, 0.0); } else { rotAxis = startZ.crossProduct(direction); } return new Frame(a, Transformation.of(Vector.of(0.0, 0.0, 0.0), AxisAngleRotation.of(rotAxis, rotAngle))); }
Thanks for answer me.
I understand what you mean until this moment :double rotAngle = startZ.angleRad(direction);
if (rotAngle == 0.0rotAngle == Math.PI)
else
}return new Frame(a, Transformation.of(Vector.of(0.0, 0.0, 0.0), AxisAngleRotation.of(rotAxis, rotAngle)));
I don't understand what are RotAngle and RotAxis, and i don't understand the return frame, can you explain more please ?
Sorry for my bad English. -
The whole process is
(1)get the vector ab and ac, where frame a as the reference coordinate system.
(2)check whether ab and ac are on the same line. If so, throw exception.
(3)ab cross ac is the normal direction of new base, where frame a as the reference coordinate system.
(4)calculate the angle from reference coordinate system's z vector(0,0,1) to the new base's normal direction by the right hand law.
I)if the z vector and the normal direction is on the same line(angle is 0 or Pie), choose any vector except z as the pivot to rotate around.
II) else choose the real pivot vector to rotate around. The pivot vector is the cross of the two vectors.
(5) value Transformation.of(Vector.of(0.0, 0.0, 0.0), AxisAngleRotation.of(rotAxis, rotAngle)) is the Transformation from frame a to the new base.
(6) So the final base frame should combine the reference frame a and the transformation together.
Welcome to any questions and suggestions.
else
Thank you very much.
i'll test it next week, i send you a throwback when it's done.
Bye. -
I try the function on the Robot, but I Have a little Problem :
At the end, I get a result like this :
[ 0, 0, 0, 1.30, 0.5, 3.14 ]
There is no transformation of translation, I don't even know how to do it, Do you know the mathematical formula to calibrating a base ?
I suspect that you have only printed the Transformation of the base frame relative to his parent(frame a).
You can get its transformation relative to World by method baseFrame.transformationFromWorld().
Also you can get the formula by the combination of cross multiplying and dot multiplying.
Maybe you can provide more details about your 3 frames/points so that I can have a verification. -
Yes effectively, i don't do any transformation, i'll try TransformationFromWorld later, (For the moment i'm working at distance from my robot, it's not that easy), so the 3 Frame a,b and c :
a= [532.5, 1, -160.7, -60.7, 0.2, -0.002, 3.1]
b= [532.5, 1, -331.9, -60.7, 0.2, -0.002, 3.1]
c= [637.7, 1, -160.6, -60.3, 0.2, -0.002, 3.1]
And my base must be : [ 532.5, -160.7,-60.7, -1.6 rad, -0.001 rad, 0.004 rad]
This is the base i get with the SmartPad function.
Thanks.
Both bases are OK.
Firstly the x/y/z in the world are the same for the taught base and the calculated base.
Secondly the transformation between the two bases is [X=0.00 Y=0.00 Z=0.00 A=1.72 B=0.00 C=0.00] which means they have the same Z direction.If you want to specify the x,y direction of you base, you need to specify more(like x goes along ab direction) because the right hand law only can decide Z direction
CodeFrame a = new Frame(532.5, -160.7, -60.7, 0.2, -0.002, 3.1); Frame b = new Frame(532.5, -331.9, -60.7, 0.2, -0.002, 3.1); Frame c = new Frame(637.7, -160.6, -60.3, 0.2, -0.002, 3.1); Frame taughtBase = new Frame(532.5, -160.7, -60.7, -1.6, -0.001, 0.004); Frame calcBase = generateBaseFrame(a, b, c); System.out.println("calc base:" + calcBase.toStringInWorld()); System.out.println("base transform:" + taughtBase.staticTransformationTo(calcBase)); //calc base:[X=532.50 Y=-160.70 Z=-60.70 A=0.12 B=-0.00 C=-0.00] //base transform:[X=0.00 Y=0.00 Z=0.00 A=1.72 B=0.00 C=0.00]
So for exemple, if i want the right angle between the new and the former base, i think i'll use the trigonometry ( Tangent ?) or is there a better option ?(see attached picture).
Thanks. -
You can use dot product to get an angle between two vectors.
I've made some adjustment of the base frame generating function, which makes a as original point, x axis along with ab, under right hand law.
Also I made the calculated base frame child of world directly instead of child of frame a.Code
Display More/** * Generate a base frame from frame point a, b, c by right hand law. The base frame' z direction is the normal * direction of base abc, and x direction is same as ab. */ public static Frame generateBaseFrame(AbstractFrame a, AbstractFrame b, AbstractFrame c) { Vector startZ = Vector.of(0.0, 0.0, 1.0); Vector xVector = Vector.of(1.0, 0.0, 0.0); Vector direction = a.getOriginOf(b).toVector().crossProduct(a.getOriginOf(c).toVector()); if (direction.equals(Vector.of(0.0, 0.0, 0.0))) { throw new IllegalArgumentException("These 3 frames can't produce a base frame."); } double rotAngle = startZ.angleRad(direction); Vector rotAxis = null; if (rotAngle == 0.0 || rotAngle == Math.PI) { rotAxis = xVector; } else { rotAxis = startZ.crossProduct(direction); } Frame tmpZbase = new Frame(a, Transformation.of(Vector.of(0.0, 0.0, 0.0), AxisAngleRotation.of(rotAxis, rotAngle))); Vector abInbase = tmpZbase.getOriginOf(b).subtract(tmpZbase.getOriginOf(a)); double rotAngleInbase = xVector.angleRad(abInbase); if (rotAngleInbase == 0.0 || rotAngleInbase == Math.PI) { } else { if (xVector.crossProduct(abInbase).getZ() < 0.0d) { rotAngleInbase = -rotAngleInbase; } } return new Frame(tmpZbase.transform(Transformation.ofRad(0.0, 0.0, 0.0, rotAngleInbase, 0.0, 0.0)).transformationFromWorld()); }
