LBR iiwa - detect a force coming from the left/right
  • robotneuling
  • May 7, 2017 at 1:40 PM
  • robotneuling
    36
    I was wondering if there is a way to check if a force is coming from the left or right (see attached)?
    I would like to put that in something like an if/else statement and program different actions :icon_smile:.
    Thank you.
    robotneuling
    Images
      • 52.77 kB
      • 490 × 173
      • 17
    Files
    2017-05-07_132343.png_thumb 7.33 kB – 20 Downloads
  • KUAJARLOS
    28
    • May 8, 2017 at 8:53 PM
    I attached example code (text in spanish):
    private ICondition gesto;
    IMotionContainer mc3;
    private CartesianImpedanceControlMode soft2;
    private int sentido = 0;
    public void initialize() {
    j1 = new JointTorqueCondition(JointEnum.J1, -15, 15);
    gesto = j1;
    soft2.parametrize(CartDOF.ALL).setDamping(.5);
    soft2.parametrize(CartDOF.ROT).setStiffness(250);
    soft2.parametrize(CartDOF.X).setStiffness(1100);
    soft2.parametrize(CartDOF.Y).setStiffness(3000);
    soft2.parametrize(CartDOF.Z).setStiffness(3000);
    public void run() {
    IMotionContainer mc3 = lbr.move(positionHold(soft2, -1,
    TimeUnit.SECONDS).breakWhen(gesto));
    if (mc3.hasFired(gesto)) {
    if (lbr.getExternalTorque().getSingleTorqueValue(JointEnum.J1) > 0) {
    getLogger().("movimiento derecha");
    sentido = 1;
    } else {
    getLogger().error("Movimiento izquierda");
    sentido = 2;
    switch (sentido) {
    case 1:
    getLogger().info("Inicio programa movimiento derecha");
    right();
    break;
    case 2:
    getLogger().info("Inicio programa movimiento izquierda");
    left();
    break;
    default:
    getLogger().error("Orden no confirmada");
    break;
  • robotneuling
    36
    • May 8, 2017 at 10:43 PM
    Thank you KUAJARLOS. I will test it soon ...
  • greengrape83
    39
    • May 9, 2017 at 3:59 PM
    Maybe you can teach a base frame by which you can measure the force in x/y/z direction.
    You can define x+ as right, y+ as forth, z+ as up. It can tell the direction correctly when force happens on axis 6/7. For force on other axis, it works not well.
    ObjectFrame oFrame = getFrame("/directbase");
            ICondition forceCondition = new ForceCondition(lbr.getFlange(), oFrame, EnumSet.of(CoordinateAxis.X, CoordinateAxis.Y, CoordinateAxis.Z), 15.0d);
            IMotionContainer container = lbr.move(positionHold(new PositionControlMode(), -1,
                    TimeUnit.SECONDS).breakWhen(forceCondition));
            if (container.hasFired(forceCondition))
                double x = lbr.getExternalForceTorque(lbr.getFlange(), oFrame).getForce().getX();
                double y = lbr.getExternalForceTorque(lbr.getFlange(), oFrame).getForce().getY();
                double z = lbr.getExternalForceTorque(lbr.getFlange(), oFrame).getForce().getZ();
                if (Math.abs(x) >= Math.abs(y) && Math.abs(x) >= Math.abs(z))
                    getLogger().info("x:" + (x > 0.0 ? "+" : "-"));
                else if (Math.abs(y) >= Math.abs(x) && Math.abs(y) >= Math.abs(z))
                    getLogger().info("y:" + (y > 0.0 ? "+" : "-"));
                else
                    getLogger().info("z:" + (z > 0.0 ? "+" : "-"));
                getLogger().info(lbr.getExternalForceTorque(lbr.getFlange(), oFrame).getForce().toString());
    Quote from robotneuling
    Thank you.
    robotneuling
  • robotneuling
    36
    • May 9, 2017 at 5:45 PM
    Thank you greengrape83. I will try your solution.
    KUAJARLOS idea seems to work fine and I learned some Spanish :icon_mrgreen:.
  • KUAJARLOS
    28
    • May 9, 2017 at 8:41 PM
    :top:
