  4. other Robots
Programming Hyundai Robot
  • danielisrael
  • April 26, 2017 at 6:58 AM
  • danielisrael
    101
    Hello Everyone
    I have several queries related to programming an Hyundai Robot.
    There are three different modes namely joint, cartesian, tool
    q1. Which mode should I select and why?
    q2. Can I record a single step with two different modes? (for example: Joint and Tool , in one step)
    Thanks and Regards
    Daniel
  • saberlars
    Robot, beyond Human..
    22
    239
    • April 26, 2017 at 8:19 AM
    - Record Type -
    Every position(Step) contain Cartesian or Joint angles.
    (Except ie - Global & Local P*** data.)
    So, You can change position type in "Quick Open"menu.
    I think should better use Cartesian(XYZ,rXrYrZ).
    Because readability better than Joint angles.
    - One position(Step) mix Different Options? -
    The answer is No.
    but you can use refer below instruction.
    S1 MOVE L,P1,S=30%,A=3,T=0
    S2 MOVE L,P1,S=30%,A=3,T=2
    When you Record Global Position Number 1 and define Tool data at No.2, robot wiil be reach different position.
    P1 is absolute Position.But S2 instruction define Move by Other Tool_Frame
    ABB, FANUC, Hyundai, Kawasaki
    Edited once, last by Robtics (April 26, 2017 at 8:22 AM).
  • danielisrael
    101
    • April 26, 2017 at 12:38 PM
    Thank you for your reply.
    If I use Cartesian, i cant reach some places in the work area.
    If I use Joint, I can reach most of the places in the work area
    I find Cartesian to be quite difficult
  • saberlars
    22
    239
    • April 27, 2017 at 9:45 AM
    Actually, robot's all postion from Sevro motors Encoder Value(HEX)
    - Guess 1 -
    Ah.. is that Step instruction include R(Shift) ?
    When calculated data out of robot's stroke, Some error popup message showing.
    - Guess 2 -
    Step Motion type P(Joint) and L(Linear) .....
    When nearst Singularity (Joint 4,5,6 Flat figure) motion...
    You can solve use Motion with P.
  • danielisrael
    101
    • April 27, 2017 at 12:36 PM
    I find bit difficult to understand what you have written.
    Please make it easy and simple
    Thanks and Regards
    Daniel
  • saberlars
    22
    239
    • April 27, 2017 at 1:27 PM
    um... Can you explain your program ?
    I can't guess your problem's main point :bawling:
  • danielisrael
    101
    • April 28, 2017 at 9:04 AM
    Please let me know how to teach a Hyundai Robot (Easy and Efficient methods)
    Thanks and Regards
    Daniel
  • saberlars
    22
    239
    • April 28, 2017 at 9:35 AM
    Not exist easy way for teach.
    U should better explain your process or Layout.
    Teach before need understand Concept.
    Concept from Interface, Tool, Layout.
  • danielisrael
    101
    • May 2, 2017 at 7:50 AM
    Thank you for your time.
    I am modifying program in Hyundai Robot(Hs-165-02).Application is Seat Handling.
    I pick the seat from Conveyor A and place on Conveyor B.
    I have no issues at pick up. While placing the seat on Conveyor B, there is always
    slight change in placing position. I checked the Jig position in conveyor B,
    it is perfect. Is there any issue with Repeatability?
    Please find the attachment showing Robot Program for your reference.
    I came across Error E0151 and warning(W0139, W0153)
    Teach pendant freezed for while (during that time it was showing back up program)
    It resumed after few seconds
    This happened only once. I would like to know the reason behind those errors, back up
    Thanks and Regards
    Daniel
    Images
      • 2.43 MB
      • 4,096 × 2,304
      • 61
      • 2.03 MB
      • 4,096 × 2,304
      • 48
    Files
    P_20170501_104747.jpg_thumb 20.19 kB – 133 Downloads P_20170501_104800.jpg_thumb 19.96 kB – 129 Downloads
  • danielisrael
    101
    • May 15, 2017 at 8:29 AM
    Dear Robtics
    I am also facing Repeatability issue.
    I teach Hyundai Robot to place a seat on a jig on Conveyor.
    When I do trial run, there is always some displacement at unloading location.
    Please let me know a solution for this issue
    Thanks and Regards
    Daniel
