Does anyone know which instruction in the aunt portal to communication s7 1200 I/O controller and R30ib CP1604 I/O device?
Communication S7 1200 with R30ib
FLAVIO PAULO SANTOS -
April 25, 2017 at 7:08 PM -
aunt portal?
to communicate with the CP1604 (acting as a slave), you need to upload a project to the PLC which includes the CP1604, then configure the ProfiNet Slave function and then at the end, assign IOs to the configured interface (this happens automatically, but you might want to check it). There is a separate manual on this, called Profinet I/O Operator's Manual...
EDIT:
ofcourse, the CP1604 needs an IP-address, which you can assign using Siemens software (Step7, TIA-Portal or a simple tool that should come on a CD with the robot or ProfiNet board IIRC).
Ask Fanuc for R-30iB Profinet_operator_manual_[B-82864EN_04] where both slave and master configurations are explained.
