Client socket in karel
  • Hi all,
    I have created a client socket that communicates with a program on my PC. It works fine. However, I want to close the socket after communication with
    MSG_DISCO('C1:',Status)
    I always get 67215 as status. A non zero value means that an error ocurred.
    Any idea what goes wrong here ?
    Luc
    ps my code to open socket is following routine :
    ROUTINE C_Connect(Result : INTEGER)
    VAR
    entry:INTEGER
    BEGIN
    MSG_DISCO('C1:',ClientStatus)--CLOSE PORT BEFORE START
    SET_FILE_ATR(ComFile_C,ATR_IA)
    SET_VAR(entry,'*SYSTEM*','$HOSTC_CFG[1].$SERVER_PORT',10000,ClientStatus)--SETTING FILE AND PORT ATTRIBUTES--
    MSG_CONNECT('C1:',ClientStatus)
    DELAY(10)
    IF Result = 0 THEN
    OPEN FILE ComFile_C('RW','C1:')
    ENDIF
    Result = IO_STATUS(ComFile_C)
    END C_Connect
  • According to the fault, the socket is in use. Not sure how useful that is.
    Quote from http://www.linuxsand.info/fanuc/code/HOST-215
    HOST-215 SM: Connection is in use
    Cause: The requested tag is in use.
    Remedy: Stop using the remote tag. If necessary close any open file to the tag and disconnect the tag by using MSG_DISCO.
