Continuous movement in a loop
  • chocobo_ff
  • April 19, 2017 at 9:12 PM
  • chocobo_ff
    32
    I am trying to move the robot based on external inputs, which updates a POS, P_offset, which is polled using a timer and updated in an interrupt. Timing of when P_offset gets updated is not critical.
    The main part of the code that moves the robot resides in a REPEAT loop. The robot follows the external input without problems, however it stops between each movement. I initially had:
    ; Set tool and base.
    $TOOL = TOOL_DATA[1]
    $BASE = $NULLFRAME	;BASE_DATA[1]
    CONTINUE
    REPEAT
    	PTP $POS_ACT:Sensor_Offset
    	CONTINUE
    UNTIL (run_saved==TRUE)
    However this didn't work. I then tried to add a second pos in there hoping that it'll give the robot enough 'look ahead' to make the movement continuous, but this didn't work either:
    CONTINUE
    P_current = $POS_ACT
    P_next = $POS_ACT:Sensor_Offset
    REPEAT
    	PTP P_current
    	PTP P_next
    	P_current = P_next
    	CONTINUE
    Software is v5.4. Any suggestions would be much appreciated :smiling_face:
    Fubini
    270
    1,863
    • April 20, 2017 at 6:14 AM
    How about activating approximation:
    PTP XP1
    PTP XP2
    robot stops.
    $APO.CDIS = 100
    PTP XP1 C_DIS
    PTP XP2
    no more stops.
    Fubini
  • chocobo_ff
    32
    • April 20, 2017 at 6:16 AM
    Quote from Fubini
    PTP XP1
    PTP XP2
    robot stops.
    $APO.CDIS = 100
    PTP XP1 C_DIS
    PTP XP2
    no more stops.
    Fubini
    Thank you for the suggestion. I tried C_DIS but had an error (can't remember what it is off the top of my head). I will give this a try tomorrow :smiling_face:
  • hotRoboter
    Guest
    • April 20, 2017 at 8:17 AM
    You can use c_ptp aproximation - c_dis is for LIN moves.
    Fubini
    270
    1,863
    • April 20, 2017 at 9:07 AM
    Quote
    Since KRC2 V5.5 this no longer is the case. You can use C_DIS in CP (LIN,CIRC) and PTP. Since KRC4 V8.x C_DIS is also the Default for PTP.
    Fubini
  • hotRoboter
    Guest
    • April 20, 2017 at 9:38 AM
    Fubin,
    in my controler KRC4 I have en error using c_dis in PTP moves.
    I remember that I used it only when I change move (PTP, and next LIN - or vice versa, I.m not sure), but when I used only PTP moves I have error with c_dis aproximation...
    Do You now why?
    Fubini
    270
    1,863
    • April 20, 2017 at 10:39 AM
    What Error? Message Number?
    Fubini
  • hotRoboter
    Guest
    • April 20, 2017 at 12:28 PM
    I don't remember now... Next time if error appear, I let You now
  • panic mode
    1,262
    13,026
    • April 20, 2017 at 5:33 PM
    before you can use approximation, you must specify approximation distance.
    $APO.CDIS=100; used with C_DIS
    $APO.CPTP=100; used with C_PTP
    etc.
  • chocobo_ff
    32
    • April 20, 2017 at 11:16 PM
    Looks like the KRC2 controller died overnight ??? so I won't be able to try this until I get that sorted out...! :mad:
  • chocobo_ff
    32
    • April 27, 2017 at 11:53 PM
    • #11
    Have updated the code and unfortunately still doesn't move the way I want it - continuously. I have tried different values of $APO.CPTP (5-100) and nothing worked ???
    Perhaps I am going about this the wrong way?
    $APO.CPTP = 25
    CONTINUE
    REPEAT
    	PTP P_current C_PTP
    	PTP P_next C_PTP
    	P_current = P_next
    	CONTINUE
  • panic mode
    1,262
    13,026
    • April 28, 2017 at 12:35 AM
    • #12
    [size=2]where is this Sensor_Offset coming from? are you aware that I/O operations trigger advance run stop[/size]
  • chocobo_ff
    32
    • April 28, 2017 at 2:44 AM
    • #13
    Sensor_Offset is updated in an interrupt that is set to run every 50ms, it's data over DeviceNet. Every interrupt Sensor_Offset is updated:
    DECL POS Sensor_Offset
    Sensor_Offset.X = dir*const
    Where dir is a direction (1 or -1), and const is how much to move by, e.g. 10.
    I have just looked up advance run stop in the KSS 5.2 manual, this is what it says:
    Quote
    In applications where this advance run stop should be prevented, the command CONTINUE
    must be programmed immediately before the relevant instruction.
    So I'll try that soon and report back. Otherwise is there anything else I might be doing wrong?
  • panic mode
    1,262
    13,026
    • April 28, 2017 at 4:16 AM
    • #14
    you may want to reduce $ADVANCE to 1 and introduce intermediate point.
