Hello everyone!
Is it possible to comment several lines standing one-by-one in another simple way instead of adding semicolon to each line?
like in java:
text
text
Hello everyone!
like in java:
text
text
No
while one cannot comment out block of code, workaround may be to simply skip block of code.
example 1:
example 2:
note, while this can help while troubleshooting, it is not a perfect replacement for commenting something out. for example code that is skipped must use valid syntax (real comment would ignore it completely even if syntax is wrong).
Both WorkVisual and OrangeEdit have comment functions which comment out entire selections of text.
yes, those are editor functions of WorkVisual.
there is no such thing on teach pendant
Hi Sir!
Need any option of Robot to carry out the comment line using Teach Pendant?
I have try to change the User Group to Admintrator but I cant carry out that
log as expert or higher
OPEN program (do not SELECT program!!!)
Open keyboard
navigate to line you want commented out and place semicolon in front of it.
close program and save changes.
Open keyboard
Thank Sir!
It is done!
