Spline motion
  • Vikramjeet Singh
  • April 4, 2017 at 12:33 PM
  • Vikramjeet Singh
    17
    m new to Robotics please let me know what is SPLINE motion in KUKA .....whats the benefit of this.......?
  • kiiwa
    369
    • April 4, 2017 at 12:55 PM
    From the manual:
    Quote
    Spline is a motion type that is particularly suitable for complex, curved paths.
    With a spline motion, the robot can execute these complex paths in a contin-
    uous motion. Such paths can also be generated using approximated LIN and
    CIRC motions, but splines have advantages, however.
    Splines are programmed in spline blocks. A spline block is used to group to-
    gether several individual motions as an overall motion. The spline block is
    planned and executed by the robot controller as a single motion block.
    tl;dr: If you have 10 points in your program, your robot will reach and stops at each point. If these points are grouped in a spline, the robot will move through the points without stopping.
  • SkyeFire
    1,061
    9,465
    • April 4, 2017 at 8:35 PM
    ...no, that's not what Spline does. Continuous motion is entirely possible with non-spline motion.
    In "traditional" approximated motion, the robot simply "cuts the corner" past a programmed point, beginning and ending the "shortcut" at a distance based on the approximation radius (and the distance to the previous/next points -- it gets a bit complicated). This means that the robot never passes through the programmed point exactly -- the point acts more like a "handle" on the overall path.
    In a Spline motion, the motion path is calculated to pass through each point, and the path between points is pre-shaped to a constant velocity and/or smoothing. This is much more computationally expensive, which is why it's a more recent development. It's best suited to things like converted CNC programs, where the intent of the program is that the tool pass through each point, rather than simply passing "near" it.
    Fubini
    284
    1,906
    • April 5, 2017 at 6:26 AM
    Just to add a few advantages:
    - Faster cycle time when using spline blocks
    - Far less situations where approximation not possible happen
    - Faster CP-motions (SCIRC, SLIN) due to model based planning: The robot automatically drives as fast as allowed by physical limits
    - Occurances of torque limit violations minimized compared to old motion LIN,CIRC
    - Better path accuracy: no more velocity dependant path deviations, what you teach is what you get
    - Better "Start-" behaviuor
    - New features only available for spline: constant velocity sections inside spline blocks, conditional stop, time based moves, move_backward, path trigger for PTP motion commands, automatic $ORI-TYPE = #JOINT, Optimal
    distribution of orientation and external axis path ($ORI_TYPE = #IGNORE, $EX_AX_IGNORE) to the cartesian path
    Fubini
    Edited once, last by Fubini (April 5, 2017 at 6:30 AM).
  • kiiwa
    369
    • April 5, 2017 at 11:10 AM
    Quote from SkyeFire
    I think, I "cut the corners" (pun intended :icon_mrgreen:) trying to simplify.
  • SkyeFire
    1,061
    9,465
    • April 5, 2017 at 3:17 PM
    :uglyhammer2:
  • DannyDJ
    68
    506
    • December 7, 2021 at 11:07 AM
    Quote from Fubini
    Fubini
    Interesting research which i found regarding improving the cycle time and comparing the old PTP and SPTP, LIN,SLIN moves, which motion type causes more vibrations...
    In this research they measured that old PTP was faster then SPTP moves...
    Files
    ElectronEng-03-03-274.pdf 3.25 MB – 305 Downloads
    Fubini
    284
    1,906
    • December 7, 2021 at 11:48 AM
    Intresting. But in my opinion has some fundamental flaws. E.g. method how to correctly measure timing are wrong. Doing it like this you also measure planning and not execution time alone. In general the difference between PTP and SPTP is far less. For old motion you always constantly loose filter time from stop to stop . For spline it depends on gear_jerk. Probably setting up gear_jerk was neglected. Also the conclusion to reduce vibrations by reducing velocity is surprising to me. Yes it works but will lead to a highly negative result in cycle times. For old motion is far better to reduce accelerations and for spline jerk (and maybe also a bit acceleration).
    Sorry, no offense for the authors but I think a lot of essential info and tweaks where not considered resulting in imprecise conclusions. But based on how academics currently works it is not surprising to me. More and more quality is replaced for quantity setting limits on how fast publications need to be produced. E.g. we had cooperation partners from academia promising more then 40 percent improvements compared to kuka that customers where never able to reproduce in reality. Asked by the customer why this happened we looked together with the University people we found their measurements where complete bull... du to many programming errors. Evaluating how these errors happened they only said compared to kuka many years of experience they had no time to learn krl due to publication deadlines. So I am always sceptical on such results.
    But finally do not get me wrong. Kuka is not perfect either and a lot of improvements are possible and also needed. But from my knowledge of Kuka they are completely aware of these deficiencies and try to work on them. But as always and probably all of you know daily business sometimes hinders you on doing the right things in the right order.
    Fubini
  • DannyDJ
    68
    506
    • December 7, 2021 at 12:22 PM
    Thank you for the detailed explanation. I was also suprised with their conclusion and how much difference beetwen PTP and SPTP they've measured...
  • panic mode
    1,300
    13,143
    • December 7, 2021 at 6:27 PM
    Well... I only skimmed the report, maybe will check it later in more detail. but as i see it, there are some problems with it.
    It shows picture of tooling on the robot yet there is no mention of load values, actual positions used, no programs are posted etc. In other words there is no way for anyone to reproduce the exact test setup and findings. For something that is supposed to be a scientific study, this is a big no-no. Basically they are able to print almost any results they like without anyone having fair chance to comment on or challenge those results directly.
    Btw. here is something from couple of years ago while i was working at KUKA. It is not a scientific study, it was a real world application. Colleague created really nice palletizer. He was tweaking it for weeks trying to get the absolutely maximum performance. We had few conversations about it and I asked him to consider comparing results with new motion instruction (SPTP, SLIN) which he did.
    After very laborious and detailed optimization, the (barely) winner was still the program using legacy motions (PTP,LIN). And that was in a program where robot practically never stops, gripper opens and closes while robot is in motion (product was both picked up and dropped on the go, "air-bomber" style) and cycle time was measured on many levels: individual transfer, one layer, entire pallet...
    If i recall that was some eighty bags of 45kg each per pallet. That is well over 3 tons or material moved in rather large working envelope and this is a real world application created by an expert with heavy optimizations, use of interrupts/triggers, all motions are approximated and tweaked to the limits, loads are constantly updated (gripper full or empty) etc.
    It is worth noting that in case of this palletizer 99.9% of path are PTP motions so the conclusion was that PTP is indeed slightly faster than SPTP. in application where PTP motions are not so dominant, results could be (and should be) different.
    Btw. this program is used in numerous plants to move all kinds of products (grain, ice, etc), usually in bags. This is part of the challenge as bags are not fixed shape and therefore do not line up as nicely as boxes. So to get 10-12 layers stack up nicely while dropping bags from the air is quite a feat.
    Fubini
    284
    1,906
    • December 7, 2021 at 6:59 PM
    • #11
    Yes usually in practical applications SPTP is a little bit slower than PTP. Well no surprise here since PTP is a second order trajectory planning algorithm and SPTP is a third order trajectory planning method. Hence PTP produces infinite jerk while SPTP is bounded by jerk. So PTP needs another technique to restrict jerk to be able to run trajectory. That is filtering the trajectory (leading to path deviances). Filtering leads to a constant time loss proportional to the filter length. If jerk limitation leads to less time loss than filter SPTP is faster otherwise PTP. My personal experience is that SPTP is up to 10 % slower depending on application. But considering the use cases of spline being essentially for Cartesian processing like glueing this is ok since usually SLIN is much faster than LIN out of the box (with heavy expensive tuning LIN can get similar fast, but that is a very dull and tedious process). So the main use case for SPTP is connecting in between Cartesian spline. This can not be done by faster PTP since it needs limited jerk for spline to work so a spline conform PTP was needed if you want features like blending motions.
    Fubini
  • DannyDJ
    68
    506
    • December 7, 2021 at 7:39 PM
    • #12
    Thank you both Panic and Fubini for sharing the detailed info and experience with using PTP and SPTP.
    Regarding the SLIN and LIN with inline forms, with SLIN i managed to get faster and more constant path velocity even for very sharp turns (90 degrees) ... especially for gluing. And also for the milling converting the LIN moves from postprocesor(still didn't came across the program with SPLINE postprocessor) to SLIN or SPLINE blocks... So in this cases in complex path motions using SPLINE moves there is a big advantage over old LIN like mentioned.
  • jaiiyer
    16
    91
    • February 23, 2025 at 10:24 PM
    • #13
    Quote from SkyeFire
    First of all thank you for always answering the doubts.. I learned so much from you guys.. thanks again.
    recently we used spline movements to smoothen out a path. However it started giving us over torque errors. When we switched back to PTP these errors were gone. Would this be because in spline the robot is tries to move at constant velocity?
  • SkyeFire
    1,061
    9,465
    • February 24, 2025 at 12:40 AM
    • #14
    Quote from jaiiyer
    The same points, with the same payload and settings? Frankly, it's very odd to get torque errors unless the robot either hits something, or is overloaded. If the spline motion were creating additional difficulties, I would expect different errors.
    Spline motions are more difficult to calculate, but SPTPs generally should not be physically any harder for the robot to perform, though the path will be somewhat different. SLINs can have issues, because the time differential of position, velocity, and acceleration all cannot have any singularities.
    Without knowing more about what robot you're using, what path, and what payload, it's hard to say anything more. For "torque errors", my first thought is that the Spline path might be running the robot into a hard stop or yanking a cable too tight, and the regular PTPs just barely avoid it.
  • jaiiyer
    16
    91
    • February 25, 2025 at 8:46 PM
    • #15
    Quote from SkyeFire
    Thank You SkyeFire. You are right about the robot being overloaded. Our mechanical department chose to not do a load study and go with the usual robot for this application. I apologize on their behalf.
    I had a follow up question. Does PTP motion ignore the load data? Or in other words is load data more critical for spline motions?
    Again i am grateful for your help as always
  • SkyeFire
    1,061
    9,465
    • February 25, 2025 at 10:01 PM
    • #16
    Quote from jaiiyer
    PTPs do NOT ignore $LOAD. This was probably a case where the Spline motion pushed the robot past its limits with that payload, and the PTP motion just squeaked past. Because even if the points are all identical, the end result motion is not.
    For example, a spline would be the purple line, the red would be a PTP for the same points:
    Where the TCP is forced to pass directly through each point. The same points, with classic PTP, would have been straight-ish from A to B, but taken a shortcut before reaching B (how far before depends on the Approximation setting), and "merge" back onto the B->C path somewhere between B and C. Then done the same "shortcut" past C and merge back onto the C->D path.
    So the PTP path would have been less distance overall, maybe had less sharp corners (resulting in lower acceleration forces), and might not have stretched the arm as much (meaning less gravity leverage).
    All other factors being equal, PTPs are probably the most "forgiving" of bad $LOAD settings.
