Greetings,
I have a problem with TCP/IP communication between my LBR IIWA and PC.
I made a multiclient-server, that is running on a sunrise cabinet as background task
and simple client app (in C#) on my laptop. The communication works well until the moment,
when I make changes in project (change server code) and run again synchronize projects.
Then communication stops work. The only solution is to change the port number.
But there are only ten allowable port numbers (30000-30010), so after ten times changing and synchronize project all the ports are "clogged".
Between two PCs works this client-server communication well, I can communicate (and changing, reseting server) on the one port continuously,
but between pc and sunrise cabinet is problem.
In Annex I attach my server code (only logic for better clarity)
I will be grateful for any help!
Thank you!
