I'm working on demonstration application, which needs comunication with PC. I tried this examples of the Server and Client:
https://systembash.com/a-simpl…cp-server-and-tcp-client/
I have to made some minor changes, but now both of this examples works on my iiwa (I can synchronise and run the project without error or fault). If the robot is the client, all works fine.
But I have problem with the TCP/IP comunication if the robot should act as server. The same example on PC worked, but if I tried to connect to the robot with the server app, I got this error (no mather, which port number I choosed):
TCP error code 10061: No connection could be made because the target machine actively refused
The problem is probably in the robot firewall setings (all ports are probably closed). Is there any way to change this settings? Or is there any opened port, which I can use?
