I find that I use the weave function often and was wondering if there was a way to make it more accessible. Specifically when you go to the next page in an edit where F1 is for [INST] and F5 is for [EDCMD] is there anyway to lock weave to F2 instead of going through [INST]>Weave every time?
Assigning to 'F' keys
- EPeters1
Depending on your system (I tested this on a R30iB with handling tool), there is a way to assign custom commands to the F2-F4 keys.
You do this by going into the system config, then going to the default logical command (item 22), going into that, and creating a name for one of the keys.
Then you go into the edit screen, and your name will show up on the key you assigned it to. From there you can edit what is in the key. In your case, you would put in the weave command.
also pressing next accesses F7 to F9 that can be programmed
