Good evening,
I have an application with two robots:
P 250 and r2000ib.
Both use the R30 iA controller.
I need to know the actual speed at which the robot is moving. Is there any system variable that returns this value?
Good evening,
P 250 and r2000ib.
Do you need the TCP speed in [mm/s] or just the override value (the "speed" setting in [%])?
I need the tcp speed in mm/s.
You need TCP speed output option J694
what's this?
Hello bidzej, do you know the variable to read the override speed?
$MCR.$GENOVERRIDE
$MCR.$GENOVERRIDE
Yes, thank you. That was the first thing I tried and it didn't work. then I found that I was writing it with lowercase....
