Wrist joint motion (Wjnt) behaviour
  • Plc_User
  • January 31, 2017 at 2:53 PM
  • Plc_User
    297
    I have to pick plates from a pallet and at some point I get rather close to singularity.
    I should use a lineair moven because I do not have the place make a curved movement as with joint movement.
    I suppose adding 'Wjnt' at the end of my lineair movement could be a solution for this.
    But I don't know how the Wjnt will behave. As I understood the TCP would follow the same line as without the Wjnt property.
    But the arm itself (axis 3 - 6) will it move a lot out of the normal (without Wjnt) trajectory?
    Will the speed stay constant if a singularity point is reached?
    If a singularity point is not run through, is the behavior of the axes then identical with and without Wjnt property?
  • jjessup
    42
    • January 31, 2017 at 3:01 PM
    With Wjnt and a linear move, axis 1-3 move Linearly, while 4-6 moves in Joint.
    You might want to change your Z angle by 5-10deg to keep it away from the singularity
  • Sergei Troizky
    67
    650
    • January 31, 2017 at 5:10 PM
    Quote from Plc_User
    Why is it a problem if eventually not reaching singularity?
    Quote from Plc_User
    Not necessarily.
    Quote from Plc_User
    Yes.
    Quote from Plc_User
    Yes, the arm may move a lot out of the trajectory without Wjnt.
    Quote from Plc_User
    This should not depend on Wjnt usage. If the singularity is reached, the speed will drop anyways.
    Quote from Plc_User
    No, the behaviour will be different, and the difference may be significant, though repeatable.
