More details please? - What variables are you trying to monitor - Locations, Reals, Strings etc. - What are you using to monitor - Teach Pendant, Terminal etc. - Small Code example may be.
hello,
I would like to know the value of a real variable from the KcWintcp.
But if you can explain me how to see them also in the teach pendant I will apreciate a lot.
KCWinTCP is an online editor (CLI), therefore you can only 'return' values as opposed to constantly monitor them. - You can monitor the IO in realtime only.
Use: TYPE real_variable PRINT real_variable LIST/R real_variable IFPWPRINT 1,1,1,1,1="REAL VARIABLE="+$encode(real_variable); (For Teach Pendant - IF Panel Window Displaying) - Or use variable display option in Interface Panel Setup - Aux 0509 (D and E Controllers - Not available on C Controller from memory).
If you wish you to monitor them constantly, I would create a PC Program containing variations of the above and run it continuously.
