The movement speed is variable.
  • young6313
  • January 20, 2017 at 7:53 AM
  • young6313
    Good evening Robotics! :flower:
    I want to move at a constant speed when I move a straight line distance.
    However, as the rotational motion of 4,5,6 axis increases, There is a phenomenon that the speed goes up so quickly.
    Thank you for your help,
    young
  • bidzej
    23
    592
    • January 20, 2017 at 9:12 AM
    can you be more specific? What exactly happens? Is it near the singularity positions?
  • young6313
    • January 20, 2017 at 9:36 AM
    Thank you for your interest.
    For example, P1 P2 P3 P4 P5 points
    All points are in the straight line.
    In P3 and P4, we moved a lot of J4, J5, and J6 axes to get the pose.
    The speed is constant when passing between P1 ~ P3 and P4 ~ P5.
    However, the speed suddenly increases when passing P3 ~ P4.
    (The same values are input for all the speeds)
    * If the singularity comes, is it sometimes faster?
    Are there any more cases where the actual speed is faster than the input speed?
    :help:
  • skalactik
    13
    111
    • January 20, 2017 at 10:36 AM
    Quote
    Yes. It may temporary increase joint speed when robot cross a singularity configuration.
  • bidzej
    23
    592
    • January 20, 2017 at 10:50 AM
    does the orientation of the TCP change significantly between P4 and P5?
    If not, then I guess that the "higher" speed is actually the programmed one. It might be, that angular speeds of the J4-J6 axes are not high enough to maintain the TCP orientation during the linear movement (P1-P3 and P4-P5 in your example) and therefore the linear speed is reduced, to allow the robot to keep the programmed TCP orientation. Then between P3-P4 the J4-J6 axes are not the problem and the robot can get up to the programmed linear speed.
    So, in short, try reducing the programmed linear speed.
