Hope this manual helps.
IRB6400 M96 Product Manual
Skooter -
January 4, 2017 at 2:39 AM -
Thanks for the support
I need floppy per installing my irb 6400 with M96 controller. Can you help me please!!!!
Thank you -
A pc-compatible floppy drive will work. If the green LED on the front stays on all the time, unplug the the ribbon cable from the back of the floppy drive and flip it 180 degrees and plug it back in.
Welcome to the forum. In the future, start a new topic to get faster responses from the forum community. Good luck with your robot.
thank you
Thank youdo you stille need it , i have the floppys but i can't make them work maybethere is anelectrical problem, do you have an os 2.1 or can you try mine and see if it works?
If you have robot ware I would like to compare it with mine thanks
