extra 7th axis motor setup on kuka krc4
  • bharathrxz
  • December 28, 2016 at 6:38 AM
  • bharathrxz
    Dear All,
    wishing you a happy and a prosperous new year in advance. :cheer:
    can any body suggest me the cables and specifications for the 7th axis motor. :help:
    thanks in advance
    Edited once, last by bharathrxz (January 11, 2017 at 3:43 PM).
    panic mode
    1,280
    13,085
    • December 28, 2016 at 6:55 AM
    sorry...no way with that little info...
    sizing motor/gearbox takes some effort.
    knowing motor type determines cable size but nothing else - such as length or version (standard or high flex - this is application dependent and costs vary).
    you also need to check if your controller has suitable drive and motor interface or reconfiguration is needed.
    RDC supports up to 8 resolvers and since you only have robot, up to two more resolvers can be connected - question is where that external axis motor is going to be mounted because on Quantec robots RDC is moving with A1. if this motor is to be on the robot arm (for example part of EOAT) then simple resolver cable with strain relief and dowel pin is all you need. if external axis is NOT mounted on the robot, you need two cables, one is from RDC to base of the robot, other is from base of the robot to motor and they will have different connections.
    i suggest to get in touch with Kuka...
  • Emben22
    43
    • December 28, 2016 at 12:43 PM
    you should have a CD inside the controller. that is the product documentations and spare parts. that includes robots and cables that you need.
