Default Parameters Invalid KSS01518
  • s2007.ravi
  • December 21, 2016 at 2:30 PM
  • s2007.ravi
    14
    585
    Hi All,
    KR120 R2500 PRO C4 FLR,Robot
    KSS 8.3.9
    I am facing the error mentioned in the subject line on one of the robots on our line when the Robot is executing the line highlighted (in Red) in code shown below:
    But it doesn't face any problem while executing the line highlighted (in BLUE) in the code shown below:
    LIMIT_R_X=ABS(250-TOOL_DATA[10].X)
          LIMIT_R_Y=ABS(Y_PICK-(VISION_SIDE*TOOL_DATA[10].Y))
          LIMIT_R_ACT=SQRT((LIMIT_R_X*LIMIT_R_X)+(LIMIT_R_Y*LIMIT_R_Y))
          IF (LIMIT_R_ACT<=LIMIT_R_MAX) AND (LIMIT_R_ACT>=LIMIT_R_MID) THEN
             OK_POS=TRUE
             IF (DEBUG==TRUE) THEN
                [color=blue]MsgNotifyTextPar("Max.Robot Limits within range by:=%1", "ROB:", LIMIT_R_MAX-LIMIT_R_ACT,,,1)[/color]
                [color=blue]MsgNotifyTextPar("Min.Robot Limits within range by:=%1", "ROB:", LIMIT_R_ACT-LIMIT_R_MID,,,1)[/color]
             ENDIF
          ELSE
             IF (LIMIT_R_ACT>LIMIT_R_MAX) THEN
                CONTINUE
                PULSE (SO_ROB_ERR3,TRUE,3)
                CONTINUE
                [color=red]MsgNotifyTextPar("Max.Robot Limits exceeded by:=%1", "ROB:", LIMIT_R_ACT-LIMIT_R_MAX,,,1)[/color]
             ENDIF
             IF (LIMIT_R_ACT<LIMIT_R_MID) THEN
                CONTINUE
                PULSE (SO_ROB_ERR4,TRUE,3)
                CONTINUE
                [color=red]MsgNotifyTextPar("Min.Robot Limits exceeded by:=%1", "ROB:", LIMIT_R_MID-LIMIT_R_ACT,,,1)[/color]
             ENDIF
          ENDIF
    I am using the default syntax to display the messages provided in msglib.src and all the other messages are getting displayed without any problem including parameter messages.
    I also tried to tweak a little bit the syntax written to see the error goes away but no success. :wallbash:
    Please suggest what I am missing here.
  • s2007.ravi
    14
    585
    • December 23, 2016 at 7:22 PM
    Anybody... :sadsmiley:
    panic mode
    1,267
    13,037
    • December 23, 2016 at 7:55 PM
    not enough info - program is incomplete. message simply means one of parameters is invalid. make sure all parameters are ok...
    for example check if calculated values are good (initialized?)
  • s2007.ravi
    14
    585
    • January 11, 2017 at 5:31 PM
    I found the problem. The reason behind the error was the parameter calculated. My logic calculates the value to be a REAL but the KUKA global function (to display parameter message) has input parameter as INT.
    However, KSS threw error only when the calculated value was in between 0 to 1. In all the other cases, the calculated parameter get rounded up to nearest integer. Any thoughts?
    For now, I have changed the input parameter data type to be Real in MsgLib.src file to resolve my issue.
