Mitsubishi RV-1a external control
  • Hi every one
    I have problem controlling RV-1a Robot using c#
    when I send Command like (1;1;GC) or (1;1;MJ 30,0,0,0,0,0) the robot didn't move
    and the controller send error (QeR601000000)
    I am sure there is some thing wrong in controller parameters (CR1-571) but i don't know what is it??????????
    if any can help me
    the following pictures are for robot parameters
    please help me
  • Hello,
    Based on the troubleshooting manual, this error means:
      • Error message: Illegal command
      • Cause: This may have occurred because data was sent before the communication line was opened via a data link,
        or an unregistered communication command was sent due to the mismatch between the versions of the
        controller and support software.
      • Measures: Send after the communication line is opened. Or, match the versions.
    Gabriel.
  • thank you Gabriel
    I read cr1-571 troubleshooting
    but my problem is how to solve this error??????
    i am very sure that connection was opened before sending command
    and there is no difference between versions
    could you please help me??
  • I tried following code :
    SerialPort _SerialPort = new SerialPort();
    _SerialPort.PortName = combo_Port_Name.Text;
    _SerialPort.BaudRate = Convert.ToInt16(combo_Port_CommSpeed.Text);
    _SerialPort.DataBits = Convert.ToInt16(combo_Port_DataBit.Text);
    _SerialPort.StopBits = (StopBits)Enum.Parse(typeof(StopBits), combo_Port_StopBit.Text);
    _SerialPort.Parity = (Parity)Enum.Parse(typeof(Parity), combo_Port_Parity.Text);
    _SerialPort.Open();
    _SerialPort.Write("1;1;OPEN=usertool" + "\r");
    _SerialPort.Write("1;1;Cntlon" + "\r");
    _SerialPort.Write("1;1;Srvon" + "\r");
    where
    connection speed = 9600
    Data Bit = 8
    Stop Bits = 2
    Parity = even
    and I tried (1;1;JPOSF) command
    every thing is ok the servo turned on and I got joints position's
    but any command to move robot niether melfa iv or movemaster didn't work
  • Hello,
    I am working on one now. I don't think your commands are correct for moves:
    First try setting a position to a variable using this command
    1;1;EXECJP2 = (50.00, 0.000, 0.000, 0.000, 0.000, 0.000) --> This will set the P2 variable to the Joint Position (50.00, 0.000, 0.000, 0.000, 0.000, 0.000)
    Than Execute the move using
    1;1;EXECMOV JP2 --> this should move the robot to the P2 position.
    This works for me.
    Make sure they RLNG parameter in the controller is set to 1 which is for MelfaBasic IV
  • Hi RobotisizeThePlanet
    thank you for reply
    I 'll try your code using MelfaBasic IV
    but i prefer using movemaster commands
    and I have already tried both of them
  • RobotisizeThePlanet is correct. You should be using Melfa basic with that robot. If you do change the RLNG parameter to switch it to move master I suspect you will find yourself in a world of pain, its only available on the later robot for backward comparability with the old e-series robots. I think you'll find the RLNG parameter is a manufacturer parameter so you'd need a password to change it.
    The software you are using "RoboExplorer" will not work correctly because it is not designed to work with movemaster.
  • just a though but if all your command work but the motion commands don't it might be that another routine has control of the arm. you might need to issue a "getm" command.
  • I know this is an old discussion. But, I am also experiencing similar issues with the RV-1A. I used to have a Matlab implementation working with TCP that was sending MELFA commands to make joint, linear or arc movements. But now, I get the error that I have no program loaded when trying to reproduce using Matlab or Python. Has anyone a functioning small communication script to connect, turn on servo, move? I am using the robot in Auto (Ext.) mode.
    As a context: The robot was offline for some years and has now been resurrected by getting new batteries and doing a mechanical stopper calibration of the joints (it shows the XYZ etc. on the teach panel).
    It seems that the community for this very old robot is extremely small... Are there other resources I can tap? Thanks a lot!
  • I found the issues for my problem. There were two: First, there was no program selected (and hence it didn't show up on the Controller display). Second, my execution commands where not formatted correctly. I was reusing old code (which was running from a Windows computer) on an Ubuntu computer. Hence I had to add '\r' at the end of the TCP messages I was sending...
  • I am having the same issue with the CR1-571 controller. Can anyone verify that this controller can issue move commands? Any other command seems to work.
  • Just figured it out...The CR1-571 can move the robot by remote RS232 commands. I needed to enter the CNTLON command. Somewhere, there is a mysterious manual that documents this proprietary protocol.
  • I need to chime in and thank RobotMd as well!
    That document really saved my day, as I have a robot and controller, but no teachbox.
    With the commands in the document one is able to fully set up the robot using only a serial connection!
    I think it would be a very good thing to upload that doc to the "Manuals, Software and Tools" sections of the forum. Would have saved me many hours of frustration
