SKILLSND
  • kosgga
  • December 9, 2016 at 12:09 PM
  • kosgga
    19
    Hi Guys;
    Does anyone clearly explain how SKILLSND works? For example "SKILLSND LGETPOS" what is the function of the LGETPOS here? I could not find good explanation for this command in manuals or notes.
    Thx in advance for your help.. :smiling_face:
  • 95devils
    235
    8
    1,951
    • December 9, 2016 at 2:33 PM
    Can you give more detailed info as to what the robot is doing. The SKILLSND is basically a robot job and the computer program environment handshake. The robot job could execute to a point where path correction is needed from a sensor. The robot job would then execute the SKILLSND "CORRON" instruction saying I'm ready. A section of the computer program would execute and correct the robot's path. When the robot reaches the line where path correction is not needed the robot job would execute a SKILLSND "CORROFF".
    There are other ways to use this instruction. This is just an example.
  • kosgga
    19
    • December 9, 2016 at 4:00 PM
    I examine the laser tracking macros. and notice that "skillsnd lsrchof" etc. and ı am new to motoman robots. command does not work with another string . so ı think these string commands like lsrchof or corron is about the communication.
    Actually the question is that where can ı examine the string commands in robot or is there any list about these commands
    sorry about my bad english
    thx in advance
  • 95devils
    235
    8
    1,951
    • December 9, 2016 at 7:20 PM
    Ok, the SKILLSND is used with a sensor function. The application is directing the robot off the taught path, correcting the robot. "CORRON" and "CORROFF" are a character string set from the robot job to the application. The text can be anything up to a certain number of characters. When the application reads that text that will trigger a section of code to execute. You should be able to search through the API to find the text.
    I don't know what software package you are using. Do you have commands that start with BSC or mp?
  • emre
    23
    • December 10, 2016 at 12:40 PM
    Hi;
    SKILLSND is used for motoplus applicaiton, so you can not read it by TP.
    There is an alarm explanation about it, that shows it is about a motoplus app.
    "When MotoPlus function (option) is used, a robot which executed SKILLSND is not defined as using MotoPlus sensor related API. Check the combination of the robot and MotoPlus application."
