Userframes
  • dewitm
  • December 1, 2016 at 10:53 AM
  • dewitm
    99
    I have 6 pallets, but the startposition on each pallet is exactly the same. I've made a user frame for each pallet.
    However, when I teach the startposition on pallet 1 with userframe 1, it won't go to the same position on pallet 2 when I open this program with CALL JOB:TEST UF#(2)
    Can someone clarify for me how this works?
    Greetings
  • dewitm
    99
    • December 1, 2016 at 11:05 AM
    My apologies, I've used search and now i have found the solution. Topic can be removed or closed...
  • TSGIR
    81
    714
    • December 3, 2016 at 7:24 PM
    Hi
    You must use relative job and convert your job to user frame 1 and after that you can call it in user frame 2 and for other user frame for each pallet. Please see leative job function manual for more information.
  • Bulo
    95
    • December 5, 2016 at 4:07 PM
    If you save the position as "Global variable position" as USER#01 (For example), if you call the job with argument "USER#02", the robot will move to that position but with USER#02 !
