hello sir welding artist, want to ask sir, if you want the output signal pulled out robot panasonic GIII procedure how sir?
Sent from my MI 4LTE using Tapatalk
I do not understand the question, could you please submit the question in different words or in your own language so I can give google translate a try?
I guess you want to have the welding on signal for external use?
Or do you want to turn on / off welding from the outside world?
In case you want an output to indicate welding is enabled / disabled (F3 in test mode).
In the upper menu bar click on “set”.
Goto “In / out”, “Status input output” and click on Weld off status output.
Check valid and select (browse) the output you want to use.
In case you want to turn on or off welding by means of an input;
Check valid and select (browse) the input you want to use.
In case you want an output to indicate if welding is on (arc-on);
Goto “In / out”, “Status input output” and click on arc-on output.
I hope this will help.
thank you sir ... it was very helpful ..
Sent from my C6503 using Tapatalk
