  4. Panasonic Robots
panasonic GIII
  • heri
  • November 22, 2016 at 12:39 PM
  • heri
    49
    Greetings sir, I want to change the robot welding wire of diameter 1.2 to 1.0. The replacement procedure how ya sir? What I immediately changed or there is a setting in the robot system should I change too? guidance please sir
    Sent from my MI 4LTE using Tapatalk
  • robotwelder2
    23
    • February 13, 2017 at 6:42 AM
    In the top menu bar click on set, go down to welding and select the power source you are using.
    The first menu item lets you set the wire diameter.
    If the diameter you want is not there you will have to buy this option.
    If you do not want to buy the option you can use the wrong wire setting, the programmed weld current has to be recalculated because it will be different from the current in the arc start line.
    (Make sure the robot is not in automatic mode.)
  • heri
    49
    • March 7, 2017 at 11:06 AM
    Quote from robotwelder2
    Thank you sir
    Sent from my C6503 using Tapatalk
  • heri
    49
    • March 7, 2017 at 11:10 AM
    For setting the output signal if the robot to move the clamp jig processes such as opening, closingor rotating manner in the robot program setting panasonic GIII TA1400 how ya sir?
  • robotwelder2
    23
    • March 11, 2017 at 9:26 AM
    see topic "signal output Panasonic GIII"
