Hi everybody,
Robot; RJ2 Controller 420İ-F long sleeve. My robot fabrication carrying capacity of 120 pounds. Carrying capacity How Can I improve this? I want to move the load 200 pounds. The settings of the robot pictures I shared. Normally the setting for the first 3 disturbance axle 20, the other 17 stops for axles. I raise these settings a little, but it's not enough. I have damaged the servo motor or the driver board artirsam more?
Regards,
RJ2 Weight Lifting Problems
byrol -
November 10, 2016 at 7:28 AM -
Sure it is 120 and 200 pounds ? and not kilo's ?
Your robot should be able to lift 200 pounds, but you will damage it with 200 kilo's -
kluk-kluk,
Sorry I wrote wrong pound. Actually weigh 200 kilo's. -
You need a bigger robot. 80kg over max payload is too much for that robot.
The end lifting apparatus of the robot which we connect to alleviating. The problem is a bit solved. Thanks to everyone.
