I need help. Control does not work in Teach. Drives do not work. In auto mode, it is working properly. What could it be?
D-Controoler
- bogmaz
Quote
What could it be?
......... ???.......what messages appear on the Teach Pendant?
In order for Teach Mode to allow Manual motion check:
- No active E stops and free from errors.
- Teach/Repeat Switch in Teach.
- Motor Power is ON
- Teach Lock is ON
- Run/Hold switch set to RUN
- Teach Speed level (2-5) for constant velocity.
- Select correct Interpolation type (JOINT/BASE/TOOL).
- Check External Trigger on X8 is made (usually not used, so probably contains jumpers between 5-6 and 7-8).
- Deadmans on Teach Pendant (middle position).
- Should allow axis keys to move robot.Hope this helps...........
It works. Thank you very much.
