Hidden job files
  • I was experimenting a bit with our robot today and found a job I hadn't seen before. It was however only visible for saving to usb-stick, it was not available to select for running.
    The job looks like this:
    ("Svetsfel" means "weld error" in swedish)
    I have two questions about it.
    First, how can it be hidden except in saving to usb? I'm guessing it's meant for some kind of error handling / retry on failure, but how do i open and edit it in the controller?
    Second, what does the attribute SY mean? I haven't encountered it before and haven't seen it in any of the manuals I have access to.
    The controller is a DX100 set up as General.
  • It's a system job. You should be able to select it under JOB, SELECT SYSTEM JOB. Believe that you have to be in Management security level. Can't remember.
  • Is it possible to dissable access to the system jobs with settings or parameters? Because I checked on both management and Yaskawa security level and no SELECT SYSTEM JOB option appeared. I do however remember it being there on the DX200 we worked on earlier this year...
  • Hello,
    there is a parameter, but i am not sure taht i am allowed to post it,
    it is a S1D... parameter.
    Maybe an administrator gives me the permission?!
    Edited once, last by fank ().
