Safe Operation System, Brake test
  • arash
  • October 7, 2016 at 8:09 PM
  • arash
    Guest
    Hello All,
    We have a KUKA robot working with safe operation system, We need to execute the brake test but we can not change the robot mode from T1 to AUT mode as when we turn operation switch to select the operation mode, the only available option is T1 Mode. I tried by activating the start up mode but it also did not work. I am hardly stuck in this problem and I did not find my answer inside manual of SafeOperation. Our system is KSS 8.3 and SafeOperation 3.3.
    Thank you in advance for your help
  • panic mode
    1,296
    13,136
    • October 7, 2016 at 8:18 PM
    you need to complete safety circuit
    don't use StartUp mode - that only works in T1...
  • arash
    Guest
    • October 7, 2016 at 8:32 PM
    Thank you so much Panic Mode
    Please may you explain more about safety circuits, is it about hardwares we have added for safety, as we already have a laser sensor to detect movements inside the room in knee height?
  • panic mode
    1,296
    13,136
    • October 7, 2016 at 8:43 PM
    you did not explain which safety interface type you have (hardware/network).
    hardware interface is using X11 and X13 (X13 only when using SafeOperation)
    network interface is using SafetyPLC and suitable network: FSoE/ProfiSafe/CIPSafety
    it does not matter which interface you have but there must be one on each robot and it must be integrated correctly - than you can move robot without dependence on StartUp mode.
    Edited once, last by panic mode (October 7, 2016 at 8:47 PM).
  • panic mode
    1,296
    13,136
    • October 11, 2016 at 12:44 AM
    KRC4 with hardware interfaces:
    Images
      • 131.03 kB
      • 800 × 450
      • 83
    Files
    KRC4 safety interface (X11+X13).jpg_thumb 27.55 kB – 146 Downloads
  • panic mode
    1,296
    13,136
    • October 11, 2016 at 3:37 AM
    Quote from arash
    Hello all
    We have an ultra kuka robot and KR C4 controller and we need to execute the brake test. I have read all the manuals for end user, system integrator's and safe operation to learn how to do it but I did not find my answer. My problem is that after preparing all the codes for parking and etc, when I want to run the BrakeTestReq program the error of KSS27022 (T1 mode prevents to execute brake test) appears.
    Did you complete commissioning? What exactly did you do during commissioning?
    Quote from arash
    I can say it that all the electrical and security connections are right as after commissioning the robot and initial brake test, no configuration has been changed.
    If anybody here helps me to sort out this problem will really help me as its already 3 weeks I am stuck with this problem.
    That is the thing - commissioning means that you have change things according to your installation.
    Are all safety circuits ok? What is the safety interface you use? Can you move robot without StartUp mode? Do you get red banner on top of the screen?
    Quote from arash
    Why don't you contact your local KUKA or for advice? Or one of their system partners? or freelancer?
    It would be much easier to help you if you had training or if you could provide some answers and usable info (screenshots, photos, archive,...).
    Otherwise this WILL take really really REALLY long time...
    I am particularly concerned with area laser scanner at knee level. I don't know details of your installation but - that would be illegal in most places.
