OPIN[16] monitoring
  • phillipe_23
  • October 4, 2016 at 4:42 PM
  • phillipe_23
    Hi all ,
    Does anyone know how can i read the value of the OPIN[16]. I'm trying to monitor when the imediate stop signal is set OFF.
    I tried to alocate the value on a variable like this ,
    Value = OPIN[16]
    However no matter how a toogle the DI[1] the value of OPIN[16], doesn't change.
  • Fabian Munoz
    134
    Articles
    1,517
    • October 4, 2016 at 10:28 PM
    Hi
    I've never heard of the OPIN signal. Could you describe what is used for ?
    Retired but still helping
  • pdl
    270
    1,545
    • October 5, 2016 at 2:15 AM
    OPIN[16] = UI[1] = *IMSTP
    OPIN's are Operator Inputs.
    They are used in KAREL to address both the SOP and UOP signals; the first sixteen being SOP's and the rest being UOP's.
    To the OP:
    Are you trying to monitor this in KAREL or TPP?
  • skalactik
    13
    111
    • October 5, 2016 at 8:52 AM
    Quote
    Value = OPIN[16]
    I did a few tries using RG and i was able to monitor the state of UI[1]/OPIN[16] using the exact same instructions.
  • Nation
    Typical Robot Error
    552
    1,933
    • October 5, 2016 at 2:40 PM
    You could interconnect the immediate stop signal to a DO in the interconnect menu. To get to it, go to the IO screen, then press F1 type, then interconnects, then hit F3 for select, and then choose ES->DO, and then set it up there.
