Hello (again).
Is possible to change the axis configuration (RCONF) directly from the TEACH? (like As in fanuc FUT, NUT)
Thanks!
RCONF in Teach
- Binarythink
What is it you are trying to do and what controller do you have?
Hi Robodoc.
I have a DX200.I need to change the value of RCONF directly in the teach. I need to cange "in situ" the axis configuration in some points.
No you can't do that.
Hi;
If I do not misunderstand, you want to change the Rconf data while u r teaching the points.
So you can do that by using Position Adjust function.you will have scrren like in pict.
Thanks EMRE!
I'll try and explain you later!
