Hi
I've Krc1 with KSS V2.x my question is
Can update with KSS V4.x without lost external axes configuration and all options ?
Hi
up.....
Talk to KUKA.
Fubini
Hi
I've Krc1 with KSS V2.x my question isCan update with KSS V4.x without lost external axes configuration and all options ?
Very unlikely.
If I remember correctly you will have to install version 3.xx first and than 4.xx.
Easiest way will be to just try to install fresh KSS 4.xx and than manually setup external axis.
Although that requires good knoledge of robot machine data.
In any case if you decide to do anything make sure you do have a full hard drive backup.
Talk to KUKA.Fubini
I asked to Kuka.....answer.....we must intervene
The problem is not install the new version of kss but the artech technology and configuration of external axes and the welder
Tech packages have compatibility with certain kss. I am pretty sure they will not work with newer one. Why upgrade?
Because when i try to create the new program, new program comes not created
so I want reinstall kss but the new version.
I dont know how configure the external axes and robot , which files i must edit and which values i must insert
if you are considering reinstall - why not reinstall same KSS and tech packages? that should resolve anything that may got corrupted. of course first make backup of everything...
if you want to upgrade contact kuka for quote.
