Hello everyone
How to change backup name default?
Now is : Backup_20140625
I want : Cell name_Backup_20140625
Without write by hand the cell name each time.
Hello everyone
You normally get "robot model-serial No._Backup_date" on IRC5
Like this 140-102045_Backup_20160922
Don't know if you can change the format?
Hi everybody,
At the finally, sombody know for change the backup name?
Thanks in advanced,
Refer to the system parameter manual, Man-machine communication, 5.3.2
Hello everyone
I want : Cell name_Backup_20140625Without write by hand the cell name each time.
hello,
In this example, "DESKTOP..." is the system name.
When taking a backup, the file name is taken according to the system name, not the robot name. As the friends above gave an example, it will first be written as "robot arm-robot serial number" and the serial number and system name are the same. However, if you want to change this, you can install a second system in the robot and write CELL_NAME30... to the system name. But don't forget to backup previous files. All information is deleted when the system is installed.
