Karel Instruction Help
  • rich43
  • September 15, 2016 at 9:41 PM
  • rich43
    16
    Have a Fanuc LR mate 200id with a 30i B Controller and want to modify a Karel program statement to add several OR statements with integer values after the <4 value. Can I just insert <4 OR 3 OR 5 OR 8 OR etc....Logic is as follows:
    • Line 67: IF (RI[2:HxBlnkGrip_CLSD]=ON AND R[1:Part Number]<4 Then;
    • Line 68: CALL M_LOAD_CYCLE ;
    • Line 69: JMP LBL[4] ;
  • rf103
    18
    264
    • September 16, 2016 at 8:12 AM
    Quote from rich43
    That seems more like TP, not Karel ..
    Quote from rich43
    No, that won't work. You'll have to compare each option with R[1:Part Number], or come up with a single statement that lets you do what you want.
    Looks like you basically need to check whether R[1:Part Number] < 8, correct? You don't have 6 or 7 in there, but since you include 8, all the others will be smaller than that anyway.
  • rich43
    16
    • September 19, 2016 at 11:05 PM
    rf103,
    Thanks for your response and my mistake, you are correct TP and not Karel.
    Also, your suggestion to compare each option with R[1:Part Number] =? may be my best option.
    Could I do this. IF (RI [HxBlnkGrip_CLSD] AND R[1:Part Number]<4 OR R[1:Part Number] =7 Then;
    Call_M_Load_Cycle
    Thanks again
  • Nation
    Typical Robot Error
    552
    1,934
    • September 20, 2016 at 2:29 PM
    Yep, you could do that. The code would look like this:
    : IF (RI[1:HxBlnkGrip_CLSD] AND R[1:Part Number]<4 OR R[1:Part Number]=7), CALL M_LOAD_CYCLE  ;
    Be aware of order of operations though. Numerical comparisons have a higher precedence than logical comparators, and the 'AND' comparator has a higher order than the 'OR' comparator.
  • rich43
    16
    • September 20, 2016 at 7:59 PM
    Thank you,
    Now if I had to add several OR statements, identical to the one just added but with different integer values, is there a better way of writing the line of code?
  • Nation
    Typical Robot Error
    552
    1,934
    • September 20, 2016 at 8:48 PM
    You could expand the IF statement to encompess the conditions you want. A mixed logic IF statement can support up to 20 items in it.
    Otherwise you could break up the IF statement into multiple if statements.
    For example:
    : IF (RI[1:HxBlnkGrip_CLSD] AND R[1:Part Number]<4), JMP LBL[5] ;
        : IF (R[1:Part Number]=7), JMP LBL[5] ;
        : IF (R[1:Part Number]=11), JMP LBL[5] ;
        : IF (R[1:Part Number]=7=25), JMP LBL[5] ;
        : !None of the above are true... ;
        : JMP LBL[10] ;
        : LBL[5:True] ;
        : LBL[10:End] ;
  • rich43
    16
    • September 20, 2016 at 10:30 PM
    Thank you. Good Option.
Users Viewing This Thread
  • 1 Guest
