  4. Kawasaki Robot Forum
Cubic S Tool Shape monitoring
  • neel
  • September 3, 2016 at 3:16 PM
  • neel
    92
    Hello All,
    Can anyone please tell how can I use tool shape monitoring in Cubic S.
    And how to configure that?
    If you guys have any ppt. please share.
    Br/Neel
  • neel
    92
    • September 4, 2016 at 5:37 AM
    It's urgent plz help me.. :help:
  • kwakisaki
    694
    4,770
    • September 4, 2016 at 9:24 AM
    Tool shape differs between Cubic-S enabled systems and Non-Cubic-S enabled systems.
    Non Cubic-S enabled systems:
    Tool shape points can be configured and then monitored for speed change in Teach/Check Modes.
    Tool shape points can be configured and then monitored for speed changes/constant area monitoring/prohibited and allowed area monitoring.
    Kawasaki has 2 ways of TOOL configuration and usage:
    a. QTOOL ON - Which is directed to BLOCK Programming - Using Aux 0304 - TOOL1/TOOL9 and Tool Shape Tab (lower right corner of each Tool Setting Page)
    b. QTOOL OFF - Which is directed to AS Programming - Using AS Commands and location variables.
    Either option has TOOLSHAPE points which can be applied - Therefore can be used in Cubic-S, or Non Cubic-S systems.
    - This is all done from either the Teach Pendant or KCWin and transferred to Cubic-S Module (Note: TCP and TOOLSHAPE cannot be configured via CS Configurator)
    Before providing information, I need to know whether you are using:
    a. BLOCK Programming
    b. AS Programming
    c. Tool changing or using 1 Tool.
    Edited once, last by kwakisaki (September 4, 2016 at 9:53 AM).
  • neel
    92
    • September 4, 2016 at 10:16 AM
    After I download OLP in the robot controller I get tool TCP and TCP orientation.
    Now I want to monitor my tool shape which I defined through CubicS with 20 point.
    Now if my tool goes out of select monitoring zone will my robot will stop?
  • neel
    92
    • September 4, 2016 at 10:18 AM
    Is this the correct procedure what I'm following for defining the tool shape?
  • kwakisaki
    694
    4,770
    • September 4, 2016 at 10:56 AM
    No, you have to configure/define TOOL and TOOLSHAPE at the Controller Side, then READ data into CS Configurator, then transfer to Cubic-S Module.
    But first you need to decide which type of TOOL configuration you are using and set TCP/TOOLSHAPE using either:
    a. Teach Pendant (Aux 0304) if using QTOOL Function.
    b. AS Commands via Keyboard/KCWin in the Controller if not using QTOOL function.
    When configured in Controller then:
    a. Connect Laptop to Cubic-S Module.
    b. Open CS Configurator.
    c. Read Cubic-S Parameters (this reads Cubic-S settings into CS Configurator).
    d. Read Robot Parameters (this reads Robot settings into CS Configurator).
    e. Read Tool Data (this reads Tool Data (TCP and TOOLSHAPE into CS Configurator).
    - You can then see all values/settings/TCP/TOOLSHAPE points in CS Configurator viewer.
    - Make Changes to Area Monitoring environment settings in CS Configurator viewer etc.
    **** YOU CANNOT CHANGE TCP/TOOLSHAPE values in CS Configurator and transfer settings back to Controller ****
    f. When finished configuring in CS Configurator - Then Write Parameters to Cubic-S (transfers ALL settings from CS Configurator viewer to Cubic-S Module).
    g. When any change occur in Controller or in Cubic-S when parameters differ.....there is always mismatch of information - So always need to make same.
    In Simple terms:
    a. Change in Controller will cause difference of setting in Cubic-S.
    b. So after change.
    c. Read in Cubic-S into CS Configurator.
    d. Read in Robot and Tool Data into CS Configurator.
    e. Write Parameters to Cubic-S and Reboot.
    f. Controller and Cubic-S settings now same, now Robot can execute program as normal.....and Cubic-S is Monitoring for correct information.
    Edited once, last by kwakisaki (September 4, 2016 at 11:13 AM).
  • neel
    92
    • September 4, 2016 at 12:49 PM
    through Cubic S configurator I made tool points of area monitoring.
    After that I can see 8 points on the picture.
    please refer the images.
    So what I did is will not run as tool shape monitoring.?
    if you can explain with a ppt with pics that will be helpful.
    Images
      • 28.01 kB
      • 480 × 289
      • 28
      • 86.99 kB
      • 1,364 × 258
      • 19
    Files
    1.JPG_thumb 24 kB – 56 Downloads 2.JPG_thumb 5.73 kB – 54 Downloads
  • neel
    92
    • September 4, 2016 at 1:26 PM
    In the CS configurator i can't find "Read tool data"
    please help
    Images
      • 37.85 kB
      • 336 × 388
      • 19
    Files
    3.JPG_thumb 24.33 kB – 54 Downloads
  • kwakisaki
    694
    4,770
    • September 4, 2016 at 1:48 PM
    Your 2nd picture says you are OFFLINE.
    - You cannot configure TOOLSHAPE data offline and transfer to Controller.......
    - Only in Controller and transfer to Cubic-S Module.
    You cannot set TCP and TOOLSHAPE data in CS Configurator - You have to set values in Controller first.
    - See Section 11.1.2 in Cubic-S Manual - This explains AS Command structure to set TOOLSHAPE and ENABLE.
    - You set this data in Controller first.
    - When finished setting.
    1. Open up CS Configurator.
    2. Press Read Cubic-S Parameters tab - Reads Cubic-S data into CS Configurator viewer.
    3. Press Read Robot Parameters tab - Reads Robot data into CS Configurator viewer.
    - When finished 'Read Tool Data' tab appears below 'Read Robot Parameters tab'.
    4. Press Read Tool Data tab - Reads in TCP and TOOLSHAPE Data into CS Configurator.
    Information in CS Configurator can now be changed/adjusted for Cubic-S functionality and Monitoring functions etc.
    **** YOU CANNOT CHANGE TCP/TOOLSHAPE values in CS Configurator and transfer settings back to Controller - You have to make change in Controller ALWAYS ****
    When you have made changes in CS Configurator, you have to press 'Write Parameters to Cubic-S' tab, in order for settings to transfer to Cubic-S Module.
    - Controller needs power cycling to reflect changes.
    Edited once, last by kwakisaki (September 4, 2016 at 1:50 PM).
  • vipinpunneri
    137
    • September 12, 2016 at 6:37 AM
    Any system switch need to be changed for enabling tool shape monitoring,??
    Thanks regards<br />Vipin..
  • kwakisaki
    694
    4,770
    • September 12, 2016 at 7:39 AM
    • #11
    No, just by enabling/disabling QTOOL either will use Tool Data set in Aux 0304 (QTOOL ON) or via Tool Data set using AS Commands (QTOOL OFF).
    1. QTOOL ON - Check AUX 0304 - Tool data and Tool Shape Tab to enable......This is used if QTOOL is ON.
    2. QTOOL OFF - Tool data and Tool Shape Commands entered using AS commands......This is used if QTOOL is OFF
    Cubic-S Setup is not as straight forward as people are assuming - That is why Kawasaki recommend training for this.
    Cubic-S is a separate module that runs in parallel to the Controller and requires CS Configurator to create profile(s) for Cubic-S Module to monitor.
    Controller and Cubic-S Robot Parameters MUST BE THE SAME (this includes model/tool/base data).
    Edited once, last by kwakisaki (September 12, 2016 at 7:58 AM).
  • ebb
    127
    • October 10, 2016 at 1:27 PM
    • #12
    Thanks a lot for your info
Users Viewing This Thread
  • 1 Guest
