Welder configured as master
  • jesusvaricap
  • September 2, 2016 at 4:17 PM
  • jesusvaricap
    259
    Hello ,
    In the past I've heard there's machine welder configured as master (brand Miller ) and robot was configures as slave.
    I've configured other welders that in the control panel you can choose master or slave.
    But what happens from the robot side ?
    What thing I need to consider? Or configure.
    I'm referring to protocol devicenet and kr2 and krc4
    Thanks.
  • panic mode
    1,278
    13,074
    • September 2, 2016 at 11:47 PM
    well, when welder (such as Miller) only works as master, robot must be slave. as a result of this, you cannot use DeviceNet on MFC card of your KRC2 and you need to buy LPDN card. MFC has simple implementation of DeviceNet with few restrictions (can only work as master, does not support coupling, master node address cannot be changed) but - it is free and for most uses it is perfect. LPDN card is a fancy card wit hall bells and whistles, can be master slave or both, supports coupling etc.
    in case of KRC4, DeviceNet is added through Kuka Expansion Bus (X44 and EL1100 needed) which typically includes both EL6752 (master) and EL6752-0010 (slave) modules but you can of course only add what you need. Either way prepare for some wiring gymnastics if you have no MultiTap module.
  • jesusvaricap
    259
    • September 6, 2016 at 8:01 PM
    Thanks panicmode!
    Sent from my iPhone using Tapatalk
