Queries about tool calibration and LIN motion with sensor
  • ashwinmudigonda
  • August 23, 2016 at 4:42 PM
  • ashwinmudigonda
    43
    I have to swap out a tool at a client's site. The MOVESETTINGS commands in the code refer to tool frame 1. When I went to Startup->Calibrate->Tool->Fixed Tool and looked at tool 1, and the numbers are a bit puzzling. I see 1287, 653, 115mm for the x,y,z values. Normally (at least with Motoman robots) the tool calibration is with respect to the flange, and the numbers represent the offset from it. The tool dimension is 12" (L) x 12" (W) x 8.25" (H). I am not able to correlate the numbers.
    I was looking at the wrong tool!
    How do I write a PTP or a LIN move with a sensor to tell me when to stop moving? What is the syntax?
    How do I modify an existing PTP or LIN move to be an approximate move? I see a line that looks like this:
    PTP xIntPoint[1] C_PTP
    Can I make it continuous by saying:
    PTP xIntPoint[1] CONT C_PTP
    Edited once, last by ashwinmudigonda (August 23, 2016 at 5:29 PM).
  • Fubini
    278
    1,886
    • August 23, 2016 at 4:53 PM
    As Panic mode says:
    https://www.robot-forum.com/robotforum/kuk…tp-velocity-()/
  • Fubini
    278
    1,886
    • August 24, 2016 at 6:24 AM
    C_PTP for PTP already states it is an approximate move. For continous path moves look at system integrators manual (sections 9 and 11, for the KRC4 manual).
    Fubini
    Edited once, last by Fubini (August 24, 2016 at 6:25 AM).
