Hello folks,
I have a small problem and wonder if anyone has a solution...
If the robot speed has been reduced from 100% on the flexpendant for whatever reason, I want to send the PLC the current speed in a group output. The code I made works just fine until I tested at 60% speed, at which point it returned a value of 60.000004!
I've tried converting to a string, back to a value etc., but am now a bit stuck as to which way to overcome this problem.
The code is:
PROC speed_check()
flexpendspeed:=CSpeedOverride();
IF flexpendspeed<100 THEN
SetGO go_SpeedValue,flexpendspeed;
TPErase;
TPShow TP_LATEST;
UIMsgBox " Robot system speed is not 100%"\MsgLine2:=""\MsgLine3:=" Robot rendszer sebességét nem 100%"\Buttons:=btnNone\Icon:=iconInfo\MaxTime:=2\BreakFlag:=spderr;
ELSEIF flexpendspeed=100 THEN
SetGO go_SpeedValue,100;
ENDIF
ENDPROC
Thanks in advance!
