Modify all points
  • Serpantinas
  • August 8, 2016 at 11:20 AM
  • Serpantinas
    81
    got a short question about syntax. How can I adress all points in program? Hope example will make clearer what I want.
    Lets say points created by inline forms and I want them all to be in one plane, so I want all points to have Z=0. How to do this in for loop?
    FOR J=1 to 15
    XP1.Z=0 ; how to change 1 to J(what syntax) that controler would understand.
    ENDFOR
    I hope someone understands because explanaition was confusing. :icon_confused:
  • Metalikooky
    78
    • August 8, 2016 at 3:10 PM
    That I can think of, you can't directly do this with the points created in an inline form. The point names could not be referenced in a FOR loop. HOWEVER, you could make those points equal to another set of points that are declared as an array. And then individually copy the array variable into the inline form point data before moving to that point.
    For example, declare an array position variable to whatever length you might need:
    DECL E6POS posVar[10] ;Using a length of 10 just as an example.
    When you create a point using an inline form, copy that point data back into the associated posVar[] array position. Once you're done with your path, you would simply add the following code to the top of your program:
    FOR idx = 1 TO (index length)
       posVar[idx].Z = 0
    ENDFOR
    And then copy the array variable into each associated inline form point before moving to that point:
    XP1 = posVar[1]
    LIN XP1 ... (I don't have the complete syntax of the inline form memorized.)
    It's clunky, but I think it's really the only way to do what you're trying to do.
  • Serpantinas
    81
    • August 9, 2016 at 7:29 AM
    Thank you, I expected something simplier maybe with variable type convertion but nontheless I'll try your smart method. The point creation could be easier especially when programing not only with inline forms, but I gues most programing is done offline anyways.
  • BluesMatt
    176
    • August 9, 2016 at 2:34 PM
    Here's a different suggestion....
    Why not use OrangeEdit's search and replace function?
    Building robotic welding systems.
  • Serpantinas
    81
    • August 9, 2016 at 3:46 PM
    Oh man.. you, this forum and this program is life savior(it's hard when you start form scratch with KUKA and don't know esential tools and programing language despite having advanced knowlage in robotics), I just thought is there beter editor where you can see structure better. I'll look into that function and I think it will be perfect. Thanks.
