hi
6eaxis hom in $config.dat How much 6eaxis all zero?
Why they will not change much in $config.dat program?
That changed after again returning to normal
$config.dat
km427 -
July 29, 2016 at 2:54 PM -
Thread is Resolved
That description was completely incomprehensible.
in the $config.dat ;home position
I want E6AXIS XHOMe= {a1 6.473307 ,a2 -42.86973 ,a3 , ....} ==0
I change and E6AXIS XHOMe= {a1 0.0 ,a2 -90.0 ,a3 90.0,a4 0.0, ....}
i save and close file after reopen it change first
how do i it?
how can i save in the $config.dat file?
Move robot manually to desired position (display->actual position->axis specific) and touch up home position.
Did you edit the file on the teach pendant? Did you hit "Yes" when the Save Changes prompt appeared?
What controller model and KSS version is this?
hello , Our friend
Kuka is KRC2 _360 kg L280
windows XP , KRC_ver 5.4.14
I need when time change $config.dat , I save my change made .
How can I do it ?
please help me -
I press YesWhat controller model and KSS version is this?
windows XP , KRC ver5.4.14
i have seen issues like this when user goes for SELECT instead of OPEN but in case of $config.dat that should not be a problem.
also if you can see it, it means you are already logged in... is the file perhaps made write protected and is there anything that writes to it? -
When you Open the $CONFIG.DAT, does the SPS icon turn from green to grey?
hello , Our friend
How can I do it ?
please help meI have merged these topics. Please do not open multiple topics for the same problem.
hello
When I Open the $CONFIG.DAT, the SPS icon turn from is grey.I can work in EXPERT , How can I understand is the file made write protected and is there anything that writes to it?
How can I add new programs in the TP folder ?
Is it necessary TP folder except p00 have another program ?
Can I sent archive for you ? -
please check whether you selecting the file or opening it.
you need to "open" the config.dat, and after making changes just submit pressing with "yes".
I "open" the config.dat, and after making changes just submit press "yes".
but after save
I anew open advertent dissave .
I need help -
I "open" the config.dat, because select is inactive , and after making changes just submit press "yes".
how can I create new model in Tp folder ?
How can I Create new programs in the TP folder ?
I sent archive for their , please check my program and
Just copy the latest $config.dat to your pc and change Home pos values there(with Notepad, OrangeEdit...).
Then upload the file back to KCR and when asks "Do you want to replace?" press YES.And by the way search didn't find any motion comand to point HOME in your program.
You don't create new modules in the TP folder. That is normally reserved for modules installed and used by KUKA Tech Packages.
You see that in the following lines have been disabled due to error on program
XPosTemp = XOnGlass1
FPosTemp = FPosLLast
XPosLLast.X = XPosLLast.X + 18
XPosLLast.Y = XPosLLast.Y - 4After a few pickup cups of KUKA due to removal of these lines has lost his position and pushes the Glass cup!
where is the problem ?
how do I solve the problem ?
I need help
please help me, -
can you help me ?
what do necessary I change $config.dat for solved problem ?
what do i do ?
please help me . -
