Strange Problem with MOVC FPT command
  • motorobo
  • July 28, 2016 at 1:12 PM
  • motorobo
    83
    Hi All.
    Since some time, I am having strange problem with MOVC FPT for some time now on DX100. I have a double circle with command as follow:
    [code]		 SET LI000 0
    		*DC
    		'DOUBLE CIRCLE
    		 MOVC P[LB007] PL=LB006
    		 MOVC P[LB008] PL=LB006
    		 MOVC P[LB009] PL=LB006
    		 MOVC P[LB010] PL=LB006
    		 MOVC P[LB007] PL=LB006 FPT
    		 INC LI000
    		 JUMP *DC IF LI000<2
    [/code]
    The problem is, the robot speed is lower between command MOVC P[LB010] PL=LB006 and MOVC P[LB007] PL=LB006 FPT than other section. Value of LB006 is 1.
    The code was working fine earlier. Is it controller or singularity problem?
    Thanks for any input!
  • roboprof
    24
    469
    • July 28, 2016 at 2:19 PM
    Where is the speed being set? On an earlier SPEED command?
  • motorobo
    83
    • July 28, 2016 at 2:50 PM
    Yes, the speed is set at the top of main program using SPEED V= x mm/s. X used 50, 70, 100.
  • roboprof
    24
    469
    • July 28, 2016 at 3:48 PM
    Could be singularity issue. Wondering if the PLs make any difference also. Are the speeds consistent if there are no PL levels? I would check both issues. If U axis and B axis are parallel at any point during the circular moves, and R starts rotating, then I would assume singularity.
